vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
That VAC line
Is the feed for your internal heater stuff, VAC cannon ball,& cruise.
The EGR is under the plenum, look under ,between the down pipes foward a bit from the distrib you 'll find it there.
The mystery connector is your EGR heat sensor.
The EGR solonoid is up by the thermostat housing.
The TPS take some small speaker wire, strip it, shove it into the connector and re connect.
I'm thinking fuel pump next...... to be sure
At that milage I'll bet your intake sock is sucked 1/2 way into the pump intake and LOADED with evil.
Mike
Mike
