M
Macgyver
Been doing some researching and talking to some people and I still cant seem to get her to start. Mike (Stingray6974) has been helping me try and tackle this thing here. I took out all the emissions stuff and the AC adn threw on the Edelebrock Performer and Holley 4150. Now that everythings back together she wont start.
I cranked the engine until I could slide a 6inch screwdriver into the the #1 cylinder head and the rotor was pointing at the 1 o'clock on the cap so I wired everything according to that 1-8-4-3-6-5-7-2. The way the ignition wires were run it was absolutely impossible for the right wires to be set in the right firing order! But thats another story that I have nothing to do w/.
So rotor is pointing to one and everything is wired in the correct order now but she still has the same symptoms. I pulled the one wire and layed it against the frame w/ a screwdriver in it and checked to see if theres a spark. When cranking it there isnt a spark but when I turn the key to the off position there is a little one. Before I rewired her there was a plume of gas out the top off the carb when I turned it to the off position but now theres not and gas runs out the top of the Holley!!!
Is it possible that Im 180 degrees out? Even when the rotors pointing to the right spot? Everything ran great right before all of this and now somethings missing. Anyone have any suggestions?
Steve
Steve
