Mac,Macgyver said:Thank you all very much for all your help I really appreciate it. This board kicks ace and is saving me tons o cash plus helping me learn everything about this sweet ride which is exactly what I wanted when I bought it!
Ok so found out how to adjust the float on the Holley adn now got it to sit parallel. So now I shouldnt drench the garage w/ gas! Hopefully. Now its onto the timing.
The problem Im having is that i cant see the mark on the harmonic balancer! Can someone shed some light on where to get. If I want it at 8degrees BTDC then thats going to be between 11 and 12 o clock if Im staring at the car from the front right? When there then the #1 piston is going to be at the top.
Then drop the distrib in pointing to the first cylinder and inthe process of dropping it and it spinning down to the bottom, when it sits it should be pointing to the #2 cylinder or the passenger headlight right!? Please tell me Im right. The part thats confusing me the most is that everyone is looking at the car from a different angle. If you could specify the angle that your perspective is please. Once I get all that done then Ill check the coil and stuff like you said robin and Bud fi it still dont start.
Gerry, youve made me realise what the problem is! Yes it is the stock HEI. So the connectors for the tach, battery, and ignition are supposed to go on the left side of the engine , or the passenger side!? I went to get the wires and plugs replaced and the way its been since is that the connectors have been onthe drivers side! So #1 wire is going to plug in at 7o'clock if the windshields at 12o'clock right? maybe this is all why Ive been getting 6-8MPG in the city and 20 on the highway! Hmmmmmm...
Im almost there! Thank you all sooo much
Your wiring sequence is correct. The ignition module in a Non-Computerized large cap 4 pin HEI has 2 male terminals on one side that connect to pickup-trigger … and 2 more on other side that connect to harness. That same old reliable 4 pin HEI has BOTH vacuum advance with a conical metal vac canister located at distributor base … and a mechanical (centrifugal ) advance governed by weights & springs that are immediately visible as rotor is lifted away. That same old reliable 4 pin HEI has its ignition coil mounted atop cap and beneath a plastic cover attached with 2 or 3 small screws. Same distributor is available from GM with P/N 1104067 and also ships with some of the GMPP crate motors.Macgyver said:So on the distributor theres the battery wire. Next to it the tach wire. Behind it the black 3 pronged ignition harness right? Opposite of where that ignition harness comes out of the distributor is another harness that has 4 pins. I thought it was supposed to have 7 for an '81? Does that mean that this distrib runs completely separate of the ECM!? I hope so.
With a non-feedback carb & non-computerized dist it should run OK. Most carbed street cars w/ large cap HEI need both vac & mech advances. Does yours have BOTH vacuum AND mechanical advances? If so, it should work ok. Seem to recall yours is cammed up … if too little manifold vacuum then a vac advance dist may not work out so well.JHL said:Will the L81 distributor work once all the computor stuff has been disconected and the carb replaced ??? My 81 has an old style HEI with vacum advance. Might be worth picking up one from a junk yard and giving it a try. J.
Jack,Jack said:With a non-feedback carb & non-computerized dist it should run OK. Most carbed street cars w/ large cap HEI need both vac & mech advances. Does yours have BOTH vacuum AND mechanical advances? If so, it should work ok. Seem to recall yours is cammed up … if too little manifold vacuum then a vac advance dist may not work out so well.
JACK:gap
JHL said:Jack, Did the 81 computor HEI`s have vacum advance or was the advance all handled by the engine management system ???J
