O-ring sealed pistons and orig calipers
  • Thread starter Thread starter red74
R
red74
Does anyone know if those new o-ring sealed pistons will drop into my original calipers?
Buy NEW calipers
Unless you have sleeved ones.
Mike
I put the O ring pistons in the SS sleeved calipers on my 69. I would assume that if your caliper bores are good...not pitted or scored, that they should fit in the standard non sleeved caliper bores too. I assume you're doing this to alleviate "air pumping" back into the system, and not to stop leakage. Hope this helps. Chuck
Thanks vigman, ChuckG for the info.
I am doing this for the cavitation/air pumping reason but also for the reliability standpoint (leaking/longevity). I'm unsure of the condition of the bores.
I've seen an o-ring conversion kit on Ecklers site (PART# 37543) but I have not seen it in their catalog that I just got. Has anyone seen this conversion? Does it includes a SS sleeve or is there a sleeve available for this purpose?
I'm building this car as a fun driver, non racer, non show car and not an original museum piece. The brakes are for my peace of mind.
red74
You might want to consider rebuilt calipers from Vette Brakes. O-ring pistons on stainless sleeves will run you just just under a $100 a caliper, and they have a warrenty.
