OBDII Code Question
Satch
New member
Lake Stevens, WA
1996 CE, LT1
My '96 CE-LT1 runs rough at idle after warm up--then smooths out for a while. All temp's normal. MIL/Service Soon light was illuminated. Scanned with Auto X-Ray Scanner and found the following trouble code: "P0151 TROL CIRCUI LOW". Can't locate this code in the ECM Code list I got from the CAC, and don't have my Service Manual yet. MAP Sensor read between 11 and 14 hg, air flow rate between 1.02 and 1.26 lb/min. I was hoping one of you might be able to shed some light--only data I thought to be odd from the scan was Oxy Sensor 1 had wildly fluctuating reading between 0.130 to 0.750V--other Oxy Sensor voltage readings were fairly stable, although the Sensor 2 readings were just under the 0.9 "rich mixture" level (data obtained while engine was at idle). Thanks in advance for any help you can give--what a great forum !!
-Satch
Thanks for the help, CKA_Racing--I'll check out the threads and take it from there.
-Satch
