toptechx6
I recently purchased an Auto X-Ray 6000 scan tool to use on my 93 Vette and other daily drivers since it is supposed to read both OBDI and OBDII data. The tool seems to work fine on all the OBDII cars (Chrysler) but will not read live data from the Vette, Auto X-Ray sent a replacement GM 12 pin cable, it did not make a difference.
The service engine soon light will occasionally illuminate on the Vette then go out after one or two minutes, the scan tool does read a code for the knock sensor circuit presumably the cause of the intermittent light. There are no unusual noises from the engine at idle or on acceleration, my concern is that the PCM may be failing since the scan tool is unable to read the live data stream. Any thoughts or suggestions are welcome, thanks.
