Hi, I'm new to this forum and also as a Vette owner. I have a black 1986 C4 with 29,000 original miles. Got the Vette from the original purchaser who garage kept it from day one - neighbor. Anyway, the car had NOT been driven for the last 6 - 7 years, or for that matter even started. After replacing all fluids, ('mopped' out the gas tank), separate heater core and motor coolant flush, plugs, battery, fuel pump, thankfully only rocker cover gaskets, and a few other small repairs, I have two questions. First, what is the normal or should I say range for the oil temp in this vehicle while driving and also at idle? Second, I know these Vettes were designed to be driven with fairly high coolant temps before the fans kick in, (unless a/c is operating), and my question is, has anyone taken it upon themselves to
run their Vettes with lower coolant temps, (190 - 200 range) and have any issues developed because of lowering your coolant operating temp? Sorry to get a little winded, but wanted to give you a rough idea of the vehicle. BTW, my coolant temps are right where Chevy designed them to be, fan kicks in around 227, and my oil temp running is in the neighborhood of 200 driving and around 220 after driving and letting it idle for a few minutes. Thanks in advance for any responses.
