7
77vette
My 77 vette, A/T, has a leak from the pipe area that fits into the radiator. I tryed to tighten the clamp without much success due to the angle. I will eventually get the right tool to do this, assuming this is the problem. Has anyone else had this problem....any suggestions???? Thanks...
P.S. Maybe I should mention, these are the 2 pipes that connect from the radiator to the transmission. The leak is coming from the radiator connection...Thanks
