I have a my new (to me Z06) that I just accidently overfilled with oil. Failed to check the manual first which instructs to first run the motor up to 175 deg and shut down for 5 to 20 minutes. I checked it cold and put in 2 qts of oil then drove for about 6 miles. Checked again and discovered that I probably was not low to begin with and now I am about 1.5 qts. overfull.
I carefully drove home never getting over 50 PSI.
Is the risk too great to also carefully drive the car about 7 miles to the dealer to correct the problem? Advise please.
thank you
thank you
