The73vetteman
I just took out the distributor from my L48 to replace the shaft and get the tacho running again. Once I had it on the bench I noticed oil dripping from the advance unit, maybe as much as a thimble full.
Anyone got any ideas where this has come from?
For background, there doesn't seem to be any oil in the vac hose. I recently had the heads rebuilt with new valve seals. (It had been suffering with oil running down the stems.) The engine has only run for 30 - 40 minutes since reassembly so could the oil be due in some way to the valve seal problem?
Last point: how much force should it take to operate the vac advance?
