Kid_Again
- Joined
- Jul 6, 2004
- Messages
- 1,171
- Location
- NJ - Which exit you from?
- Corvette
- 65 SB Roadster, 66 BB Coupe
Ever since the sb was rebuilt, I've had problems with each plug oil fouling.
After one hell of a lot of tinkering, I replaced the intake with an edelbrock and that helped a bit. The plugs continued to be wet but the MSD fired through the fouling. But it's not right.
In a previous post, someone suggested pulling the rocker studs and then sealing the threads. I pulled one intake and one exhaust studs and, as expected, they are blind pockets.
Even though I pulled the intake before, I pulled the intake again. It was either that or I had no valve oil seals (I could see I did, the heads are new Dart Iron Eagle IIs) or half of the piston rings were left off :confused
This time, when I pulled the intake, I had the garage lit up like Yankee Stadium so I could see. Now I can see each intake runner is wet with oil. Also, it looked like the manifold side of the intake gasket was wet with a lot of oil. OK, so I'm pulling oil directly in from the rocker valley. I'll be darned.
Before I get to the speculation about why I have mismatched mating surfaces, can I use Copper gasket maker on both sides of the intake manifold gasket to seal the intake when I reassemble it? I KNOW this is the not the correct solution but I am not pulling those heads. Period.
Which intake gasket do you recommend (original 327, .030 over).
As to the cause, my guess is that the guy who did the engine rebuild decked the block a BIT too much. No?
