76okievette
I have an oil leak from the front of my engine. It right around the time chain cover, or the front of the oil pan. Could this be a "front seal" leak and if so how hard is that to correct? Also can the oil pan be pulled on a L-48 1976 with out raising up the engine? I also a small leak at the rear of the engine or what I have always called the "rear seal" area but I will worry about that one after I get the one if front fixed. Thanks,
GO SOONERS
GO SOONERS
