C
celeryman22
Hi I got a broken bolt in the block that holds the oil pan on. Its right in the middle. The block is getting ready to be put back together. I tried to extract it but that didn't work (i broke the screw extractor). So I'm thinking I need to use a helicoil. Where can I get a kit that won't cost me an arm and a leg. I need I can get he coil itself for 1.00 or so. Canyou confirm the bolt size of 1/4" x 20. How long of a coil will I need?
Do you need the kit to install these? I did it back in high school but I can't remember now.
Mike
Mike
