C
corvdesign
I need to change the oil pan gasket in my 77 L-48. Engine is in the car. Any problems doing that?
Thanks,
Corv
Thanks,
Corv
corvdesign said:Thanks for that info. Where is Washington, Michigan?
mvftw said:If your doing the pan, consider the timing chain (if it's oringnal), oil pump & shaft, & rear main seal. At least use the Fel-Pro one peice seal...
