Chris Kennedy
At some point in time I will probably replace my standard 4 qt. pan with one from the aftermarket, largely to try and increase capacity and reduce oil temperature a bit (I would like to stay away from the extra plumbing of an oil cooler). I am concerned about clearance (both ground clearance and clearance of things such as the power steering piston rod), and wonder if anyone can recommend a replacement pan that does not have clearance problems. I have looked at Milodon, Moroso and Canton, yet have never felt comfortable with the advice I have gotten from the various technical departments. Also, do people prefer the Fel Pro of the Mister Gasket one piece oil pan gaskets?
--Chris Kennedy
--Chris Kennedy
