O Vette
Could someone give me an opinion, please? I was looking at a 1975 with 63K on it and noticed that after car was running for about 4-5 minutes the oil pressure gage was reading a bit below 40. It was a nice warm day. The car recently had a new oil pump installed. Is that pressure level something to be concerned about and could the lower reading have anything to do with the new oil pump (not installed correctly). Could the new oil pump have been installed to increase an even lower prior reading? I've read through some posts on this subject and I realize this could be a stickler of a problem with many causes. I guess my main questions are - is oil pressure that reads a bit below 40 okay and what would be the symptoms that would cause you to replace an oil pump? Thanks for your help.
