minifridge1138
Where is the oil pressure sending unit on a 1982?
The temp sensor is on the drivers side of the block between #1 and #3 cylinders.Ok, if that is the oil pressure sending unit, then where is the oil temperature sensor?
Basically, i'm leaking out from someplace around plug 8.
If I drive gently, i park and no leak.
If I go out and "play" a bit, then I park and within 2 minutes have a puddle under the car.
Any ideas?
Not a head gasket, but a manifold gasket rear seal.ok, well that's not the leak. Wrong side, and wrong plugs.
I'm not leaking coolant, so I don't think it is a head gasket.
I would bet good money that my oil pan is leaking, but i'm not sure how an oil pan leak would get up to #8 plug.
Thanks for the info.
Yeah, your oil return passages in the head gaskets. But if you're certain the head gasket isn't leaking, I would say valve cover gaskets are a good bet.I put the intake manifold on in September, so I hope it hasn't already slipped.
Honestly, i can't remember if i put silicone sealant on it or not.
The back of the motor near the manifold is dry. No oil there.
I was looking at it with the motor running, hoping to see oil spurt out. I couldn't find anything. I'd give it a shot of throttle and would see a puff of blue smoke. Is there anything around plug 8 that has oil in it and would get a boost in pressure under higher RPM's ?
I'm hoping that it is just some loose oil pan bolts. I'll tighten them.
I think i may also replace my Castrol Synthetic with a Castrol Organic for higher mileage engines.
Actually, i'm not positive that my head gasket isn't leaking. I'm not leaking coolant, just oil. I would think that if a head gasket was blown, i'd be leaking both.
