M
magnesium
I have a 350, 1976... When cold, oil pressure is at 40, When hot, oil pressure at idle speed is about 20... hot, cruising speeed about 30... is this normal? or too low??
I ve changes the oil today for 20/50... now its steady at 40... great!!! thanks buddyTwin_Turbo said:it's normal, when the oil gets hot the viscocity goes down, meaning it's thinner. Thinner oil has less problems making it through the oil passages so the restriction is less. Pressure is a restriction to flow > pressure goes down.
