Mad-Mic
Gone but not forgotten
thats right let me hear them. did you set and achieve any goals? any let downs from mods? broken parts? lets here the blood and guts of it! i know there is a few racers in here and part time guys that track their cars!
i'll start off with mine...
started the year really good with a strong car. got it dynoed with mild bolt on's after my LT header swap. car made 245 rwhp and 355 rwtq range. only got 1 pull due to a EGR hose to #8 cylinder i had rigged up failed on the run. (had high temp hose temporarily holding it connected) i got ran in hot also at 220+ water temp. all in all i was still happy especially with a 12.9:1 A/F ratio. the car was strong and showed it end of March. this was my first track day in not so good air and with the TPiS LT header install the car picked up 3+ mph on a 700+ DA day compared to -1500 DA with previous best ET and MPH! the car picked up a tenth and left another tenth or 2 on the table. i was very happy and thought i was on my way to 12's on a very mild bolt on A4 2.59 L98 car!
Fall Racing season hasn't been so good to me. have been experiencing loss of ET and MPH and haven't had the time to trace the problem
but i'm hoping i can get it back upto par before season's end. the cars running 4 mph off and most likely 4 tenths which puts me at a 12.8x at 107+ mph which should be failry accurate with weather calculations on -1000 DA or greater air. i was really hoping to get a 12 second time slip especially since i know the car has it in it. my other goal that i can still achieve is 300 rwhp and 400 rwtq on stock internals and stock TPI. i think the car is very close to it especially if i can get it dynoed in race conditions with the water temp cooled. this is something that i'm gonna start working on is getting the Code worked out and finding out why the car is running rich and go from there. if i can get that done before season's end i'm sure a 12 second slip is coming my way for this car although it's not setup for 1/4 mile with stock 1600 stall and 2.59 gears. once i get that 12 second slip heads/cam/intake and a little shot is going on the car over the winter while i do the 396 build.
ok your turn!
ok your turn!
