Spent the afternoon putting my new Pro Topline heads on. Now that they're on, I have the nagging suspicion that I forgot to do something. It's most likely just me (and my lack of confidence in my automotive skills), but just in case... here's what I did.
1. Used a gasket scraper (really a putty knife) to remove all traces of the old gasket.
2. Used an acetone-like substance to remove all traces of grease/oil/antifreeze from the block (heads are new, so I didn't do anything to them).
3. Chased the threads for all head bolts with a high-quality tap.
4. Vacuumed out any crud that was down in the cylinders, and wiped the bores with transmission fluid (the only thin oil I have). Found some extremely small scratches in a couple bores; can't do anything about it now.
5. Installed the new composite gasket, black-line-side towards the block.
6. Put the heads on the two studs.
7. Put a washer on each bolt (these are ARP; the washer is concave on one side - does it matter which way it faces? Directions didn't say and I figured they would if it did) and coated a couple threads with Permatex hi-temp teflon sealant.
8. Hand-tightened each bolt, then went around in the right sequence tightening them all to 45, 55, and 60 ft-lbs in turn. Before the final turn to 60, backed each bolt off and re-tightened, per ARP instructions.
9. Washed hands and had a beer.
Does this sound about right?
Thanks... Yes, I'm a nervous virgin - haven't done heads before on any vehicle.
[RICHR]
[RICHR]
