B
Big D
I have a 1959 corvette that someone put a 56 265 in it. When I first got the car, I replaced the ignition system, put new gas in and she started up pretty good, I got a back fire when I throttled up, but other than that, she idled at least. After a short while, she overheated, I shut her down and replaced the thermostat started her up again and noticed vapor comming from the right head, I checked the oil and saw evidence of antifreeze in it, so I went the cheap way put, pulled everything apart, changed out the head gaskets, intake manifold gaskets, you name it, I changed it. When putting the heads back on, I forgot to count how many turns each rocker took, so I have no idea if they are set right.
Now the car turns over, seems to try and catch at a certain point then she does not start, the carb is getting fuel, the plugs are getting power, I think the valves are not opening or closing properly and that is preventing statup, I have good oil pressure when cranking and so far I see no evidence tha the head gaskets are leaking. Any valve help?
