Bolisk
Hello all!
I'm still trying to root cause my misfire at idle from my passenger side bank. Here is a video of what it sounds like:
https://www.youtube.com/watch?v=d_pNIEegRt0
The driver side runs nice and smooth. . .and the puffs at the exhaust pipe are all even and nice.
The passenger side spits and puts. . .you can tell when the camera shifts to the passenger side.
I performed a leak down test on both banks of the motor ( when cold ) and all the cylinders checked out at about between 10 and 15% loss. During the compression stroke. . .the only air noise was from the oil fill cap (e.g. past the rings). There does not appear to be any leaking exhaust or intake valves as far as I can tell.
The vacuum at idle is nice and steady around 20. However every couple of seconds or so. . .when it seems like the engine misfires. . .the vacuum will drop by no more than one point.
I did have at one point the spark plug gaps too tight. . .and once I fixed that gaps. . .it ran a ton better. . .but it still does it. . .just much less frequently than in the video provided.
I have not performed cranking pressure test yet.
I would have bet money that this was some kind of weak spring or bad exhaust valve. . .but now I have no evidence to suggest any of those.
This only appears to be an issue at idle. . .however, the car will backfire (out the right exhaust) when the car is downshifted and the rpms go up while not applying any gass (engine breaking).
Any ideas?
Plug wires?
distributor? (I have brakerles SE electronic ignition in it)
Coil? (would expect a problem on both banks then)
fuel dilevery?
Exhaust poor back pressure? (I do have headers with poor fitting pipes just down stream of the collector.)
Any help would be appreciated.
-Jon
Any ideas?
Plug wires?
fuel dilevery?
-Jon
