LanceB
Well got the 75 and spongy brakes and brake light on. No fluid in rear portion of master cylinder. So get on jacks, wheels off and checking the bleeder valves. All open but one...now I am in a real pickle...it broke off in the darn caliper, figures. I tried getting the caliper off but rusted tight. I have changed the calipers on my 81 and bros 77 and I had problems (torching/penetrant an old stuck bleeder valve but it eventually came off), but not like this. I guess the good and bad news is the brakes have never been touched. I was hoping to bleed it, change all the bleeder valves and get fluid in it to see where/if leaks but now I am stuck. What can I do? I have to say re-threading the caliper for a new bleeder valve is a skill that is not in my vocabulary. I can turn a wrench and read instructions but I am not as advanced I need to be. And I think getting the calipers off is going to require some heavy equipment and more than me cranking on it.
If I could just get this valve replaced I could at least get it on the road. So I am looking for advice on re-threading and replacing the bleeder valve first (what about chips of metal from rethreading, do they fall in the caliper and will they be flushed out when bleeding?). If a new caliper is the best answer how in the world can I get this thing loose. I already torched, sprayed PB and cranked on the two bolts but they won't budge. I will offer this too: if anyone is in the Louisville, KY area I will pay you, feed you well and supply beer if you want to bring your expertise to my garage and we play horsepower TV for a little bit! But advice is very welcome.;help
