One piece oil pan gasket
Desert Nomad
Torrance, California
1967 Marina Blue 427. 2008 Z06 Victory Red
I'm replacing the oil pan gasket with the Fel-Pro one piece unit. Should I use silicone on the gasket or just put it on dry. I've heard just a little in the corners may be enough to hold it in. Just don't want to have to re-do it later. Any suggestions are appreciated.
Desert Nomad,:confused
Just use a dab of RTV in the corners - that's all it needs; you'll like the pan hold-up pins :)
Thanks JohnZ. That completes the pre-planning of this job. By the way, what are the pan hold-up pins?
Desert Nomad
Desert Nomad
They come with the gasket - nylon threaded pins with barbs on them - you thread them into the pan bolt holes, raise the pan into place over the pins, and the barbs hold the pan up in position while you get the pan bolts started. :)
Those pins are really slick. I wish they would have had them years ago. Another option is to flip the engine upside down like this. (It helps if it isn't in the car). The instructions call for a dab of sealer in the corners where the rear main cap meets the block and also where the front cover meets the block. The rest goes together dry.
Tom
attachment.php
Hey, everyone's gotta have someone to make fun of, right? I'll be the goof-up here again, okay? :L
Tom, when I had the engine out last year, I had it on a stand just like you picture, all neat, clean and tidy, lots of room to move... no problem, right? Wrong - you still gotta PAY ATTENTION when putting the two pieces (pan to block) together. I screwed up and let the end piece at the front twist slightly. That was the reason for my major oil leak at the front of the block. :hb
And we all know it's far easier to install a pan gasket with the engine out of the vehicle; sure is a PITA with it installed. :hb :hb
I'm sure not going to make fun of you Ken. At least not until after this thing is running and not leaking. :L
