Rogue
Hi everyone. New to the forum.
I'm currently considering purchasing a 1982 Corvette and I was wondering if you guys and gals can give me some expert/experienced advice. I have never owned a Corvette. This will be my first. I'm buying to restore it to original condition and keep it as my weekend toy.
The car in question is in all original condition with 131k original miles. It is also a 20+ year old car so it needs a lot of work. Body is straight but needs a new paint job. Interior needs to be redone as the upholstery is cracked and surfaces worn from being out in the Socal sun everyday. Althought the dashboard is in good shape. Weatherstripping/rubbermoldings around the doors needs replacement as they're cracked and rotting as well. The seats needs to be replaced. The left side headlight doesn't open. The power antena is broken. It also has an aftermarket CD player with speakers cut out on each door so new door panels need to be fitted.
The car does start right up and idles at around 700 rpm. But, while idling, the car shakes a bit. Not vibrate but shakes. Hmmm....No smoke from the tailpipes though. The engine revs up easily and smooths out once running. There seems to be good power with no unusual noises from the 350 V8. Just a bit loud. The auto tranny has 50k miles on it (it was replaced). The throttle requires a bit more force to push down than what I'm used to in modern cars. The brake pedal goes a long ways down before there's resistance. The car wanders all over the place while at speed. It pulls strongly to the right when brakes are applied. The suspension is stiff and bouncy. The car does have the wrong size tires that are well worn: 275/60/15 on the factory wheels.
The owner wants $5600 for it. I'm thinking I'll need another $5k to restore the interior, body, suspension, & brakes. According to a Corvette publication, a "crummy" 1982 'Vette should be priced at around $6600 so I'm thinking $5600 is good.
What do you all think? Good deal? Can anyone give me an idea how much it would cost to rebuild the engine/tranny/differential? Basically the whole powertrain to factory specs? What about to rebuild the chassis? Like new bushings, shocks, springs, brakes? Is 131k miles a lot so that the engine requires a rebuild?
Will another $5k be enough to bring this once beautiful car back to its original condition? Pls. don't laugh as I'm a neophyte at this but I still really want my Corvette. I just don't have $15k-$30k to pay on a 1995 or newer model with little wear.
Thanks in advance for the help.
