Outside Temperature Sensor
vet'svette
Active member
Newburgh, NY
1977 Blue Coupe, 1990 Red Coupe
The automatic a/c controls displays the outside temperature but mine will not display the correct temperature until I hit a bump etc. Where is the outside temperature sensor located, based on what I've said does it need to be replaced?
Thank you,
Mine is located in the area in front of the radiator on the passenger side. Crawl under the nose and look up in that hole. It should be there.
If it works when you hit a bump it could be a loose connection or a bad sensor. Check the wires first.
