Re: Get your mechanic's license here....
c5d said:
For a gasoline engine, the perfect air to fuel ratio is 15:1 (15 parts air to 1 part fuel by weight).
14.7:1
That's the "perfect ratio" (ever bit of air matches up to a bit of fuel, so there is no unused air or unburned fuel). However, peak power tends to be closer to 12.5:1.
Stallion, basically, the issue is definitely one of getting the correct air:fuel ratio. Carbs only really meter the fuel correctly when they are flowing near their peak flowrate. That's why we have "primaries" and "secondaries." The primary bores are smaller, so they are flowing closer to their peak, in low-throttle situations. Then, if everything is set up right, the secondaries will open just as the primaries are reaching their peak, but before they become a restriction, so that the engine now has new, larger bores to flow the extra air and fuel.
Having a carb that is too large, means that the area where it is near its peak airflow (and, therefore, metering fuel most accurately) is smaller. So, when you're at idle, the mixture can vary greatly, resulting in poor idle. And, since most "in-town" driving is done at part-throttle, it is also subject to that improper mixture.
The air-valve secondary used by the Q-Jet eliminates much of that problem, since it meters based on the force of the air entering, not merely its velocity through a venturi. It's much harder to over-carb with a Q-Jet than with other carbs, but if you were to stick a big ol' 800-CFM monster Q-Jet on a tiny 4-cylinder, you could manage it. If you stuck that same carb on your Shark's engine, you'd probably not notice the difference, in msot driving.
Joe
