G
Gerry
OK, my 67 rdstr and I have a problem with overheating and I am open to suggestions. I tested the car out the night before leaving to bring the car to Stahl and it was fine but it was a cool night and I did not sit idling for 30 minutes. The next day (92 degrees) while en route to Stahl headers in York Pa. in this I ran into construction traffic at multiple places. While the car (540CI/650HP Shafiroff engine 5spd Keisler trans) was moving at 25 mph or higher I had no problem (160-180) in fact the faster (100 MPH) the better (160 degree temp). Once it was stuck in traffic and stopped the temp climbed to over 230 before I shut it down. I have a Be Cool rad (but not the biggest one due to them removing it from market for redesign), 3350 CFM electric puller fan, 160 degree modified roberts thermostat (always some flow going thru it), stewert high flow aluminum water pump. The car is at Stahl Headers now so I will be limited with time and what I can do to it to solve the problem. Here is what I plan so far given my limited situation. Also, I know the headers will let it breath better as I had the stock exhaust manifolds on for the trip to Stahls but the problem is at idle when the car isn't moving forward.
1) I will try and install a 17 " flexalite mechanical fan in addition to the electric fan
2) I am going to use purple ice coolant additive
3) I will retard the timing to 30 degrees at 2500 rpm (It was set at 35)
4) I have the moroso restricter plates and can try the 1 " dia hole in place of the thermostat.
That's all I can think of right now. If anyone has any additional suggestions or thoughts please speak up.
Future ideas:
1) Also has anyone any experience with Evans NPG+ non water based coolant?
2) Can a pusher fan be mounted in front of the rad without cutting or modifying the car as I want to be able to return it to stock if necessary some day?
I have seen some pics of the headers and pipes from Jere S and they look nice.
Thanks for any and all help.
Best regards,
Gerry
Future ideas:
Best regards,
Gerry
