'04 Torch Red
Anyone replace a power steering control valve?...Mine was leaking so I had a new one put on(I watched) and now the steering is very hard when I turn right...the mechanic adjusted the valve for left and right pull...could it be a defective valve?...steering was ok before the replacement...I also had all hoses replaced...:confused
Thanks...
P.S., I used a part made by A-1 Cardone(original equipment rebuilt part)...should I have used a GM part or an OEM part?
Thanks...
