Wavedoggie1
My 07 threw a code P0449 and had a burning smell. Re-seated the gas cap and reset the code. The code repeated a few miles later. Put the car on a lift and found a mouse cooked to the center exhaust support (Explained the smell anyway). Set Evap vent ON and OFF with no click or vibration. The coil measured several Meg ohms, and did not click when directly connected to 12V, so it is probably bad.
I also checked the control wiring and it read 11.6V and did not change when commanded to open or close with a diagnostic tool. I am replacing the Evap vent valve ($25). There was no short, so it seems unlikely the ECM is bad too. Anyone have some insight to this problem?
