What did they say what they did to the EBCM? Did they know what your codes were?
They did not say, and yes I gave them the same information as I gave you. They did say that GM EBCM's had a known problem with solder at the internal relay.
I'd say that if you applied a 10-amp current to various ground circuits to "test" them, that was likely a mistake.
I'd stop guessing at "new" ways to test your car's wiring, get a copy of the Factory Service Manual and follow the diagnostic instructions listed for the current codes which are stored in the various chassis modules.
Most who try and second guess diagnostic procedures get into trouble pretty quick as far as cost.
With all due respect Hib if you think checking for a voltage drop is new then I don't know where you have been for the last 50 years. Voltage drop was among the first things I was taught in electrical troubleshooting AT the DRC (Dealer Repair Center} in Detroit by Gm instructors. Living in Michigan is handy, I have spent many days at their training center in Warren since 1985. Sometimes for a week at a time
AND if you read the FSM it states in diagnostic aids to check for "A wiring problem, terminal corrosion, or poor connection in the requested torque circuit"
STEP 2 states "Inspect the EBCM ground and PCM ground,making sure each ground is clean and torqued to
the proper specification.
Without testing the integrity of the circuit after that how would you know if a wire is worn thru or corroded somewhere in between?
HA, a strand of wire the size of a human hair will have 0 ohms and will show 12 volts until you put a load on it, This is where the service manual assumes that you know this and have the knowledge and ability to test and diagnose the circuit and come to a conclusion.
So you accused me of making a mistake and guessing, then second guessing the FSM!
There was NO guessing, it is called going to the next level when standard diagnostics where inconclusive. AND I bet every mechanic has had to go there and some wish they knew how
BUT thanks for the insight and I do take all criticism lightly and I DO learn from it
Doug
