I am restoring a 74 BB convertable.  It will be a driver not a show car.  I have two issues with the hood that I am looking for advice on. Someone with experience with fiberglass/paint should be able to help.  I will post 2 pictures. 1) a spider looking spot located directly above the carburator center rod. So I am guessing that in the past life someone closed the hood with sonething in the way.  On the bottom of the  hood at this location is a spot the size of a quarter that looks like bondo.  Any advice on the proper repair?  2) A spot about 20 inchs wide covered with dots.  Not sure what I am dealing with here.  Did some discovery using 600 grit wet paper and the primer shows thru long before the dot is leveled out.  Again any advice welcomed.  Want proper repair prior to thinking about painting.
