overspray
First definitely look at Zaino. The clay bar process is part of the Zaino system. It removes contaminants, brake dust, rail dust, etc from the surface. It prepares the surface whether your going to use Zaino or another product. It's a must for brand new or used Corvettes. New one's have rail dust from being transported. The brake and rail dust are micro fine metal particals that embed in the paint and destroy it over time. Zaino has very good details about each product what they do and how they work (
www.zainobros.com).
The repair shop is most likely going to use a product called 3-M Finesse-It II (spelling?). Its basically a liquid 1000 grit sand paper. It will remove most scratches and paint errors, but its least effective by hand and takes skill with a buffer.
Before I would take the more drastic approach with Finesse-It, I would highly recommend you try the clay bars. You will be truly blown away at the results it produces. And if your planning on applying Zaino, it will make the finish look so deep like it has several extra coats of clearcoat on it. The best way I can describe a finish that has Zaino, it looks like its optically perfect. And plan the day for it, it takes a while to cover every square inch of a C4.
On dark finishes I would higly recommend using the Zaino Z5 product to remove any swirl and scratches. These are the little fine scratches that appear in the surface, you can see them by varying your view of the painted surface under a good light so you can see the reflection in the surface. Lots of times they occur from just washing it and drying it. The Z5 will remove them all. The more times you put the Z5 on you will see fewer and fewer scratches until they are gone. It took about 3 times on mine to remove every fine scratch. It appears afterwards like its a perfect sheet of plastic glass.
As for rubbing compound, I would stay away from that at all cost. I realize you've already used it. The 3-M product is much milder to the surface but neither compare to clar bar which is harmless yet good for the surface. I do mine about once a year, just to remove any new contaiments that have since occurred. And it doesn't affect the existing application of Zaino.
For myself when I got my 93, it had these very fine chip-like marks in the upper rear quarter panel similar to chips from gravel but way to high for that. I tried the Finesse-It on them and on an area on my hood to try to remove some overspray and those chips. It didn't work that well by the hand method. Then I got the clay bars and it completely cleaned my hood so that now it is optically perfect and those chips on the side were virtually gone. I have spotted less than 4 or so, from what was hundreds of them. I was totally amazed and would not have believed the results if I hadn't done the work and seen the results myself.
Trust me on the Zaino. You can spot a Corvette at a show that has Zaino on it. It is so obvious. Oh Ecklers carry's the Zaino products too. But the Zaino website has tons of details on it. Also if you email Sal Zaino he will respond very quickly to answer any questions you may have.
I wouldn't be so enthusiastic about the products if I hadn't seen the results and believe in them. A co-worker has a 95 polo green. Ours both have about the same milage and looked similar side by side before I put the Zaino on (I use to use Liquid Glass) but now when the are parked together its like night and day difference. My 93 has such a deep deep shine, not a scratch in the reflected light and it has so much more brilliance to the color.
Good luck, Lani
