G
GATOR454
I finished painting the Engine. Here are a couple of before and after pictures.
I used 500 degree chevy orange engine enamel for the top and the front. For areas around the exhaust manifold I used 900 degree VHT caliper paint in real orange. The color was almost an exact match to the chevy orange. It was just a shade redder than the orange I was using so just before it dried I misted it with the chevy orange. After everything was spray painted I hit all the areas that the spray could not get to with a brush (even the back of the block). I sprayed paint into an old plastic yogurt container and let it sit over night to thicken. If I needed it a little thinner then I sprayed more thin paint into the container.
After it dried for 24 hours I cured it with a heat gun.
I didn't paint the valve covers yet. One of the previous owners used the valve covers as a fulcrum to tighten the A/C and alternator belts, so I have to remove them and bang out the dents before they are painted.
The Engine bay is next. I cut the mask at the edge of the engine bay and folded the inside mask over the engine block. Then I added more paper and re-taped all of the edges.
More to come latter
David
More to come latter
David
