bigjim
New member
Any one using Dash Logic? If so, how did you hook it up besides plugging it into the cars data port? How are you getting al the data?
I have plugged it in and got the following: Pg. 1 = HP & Torq; Pg. 2 = 0-60; Pg. 3 = MAP - MAF; Pg.4 = Load - Knock; Pg. 5 = Trans Temp; Pg. 6 = Intake Temp; Pg. 7 & 8 = Analog 1 & 2. This all there is? I was led to believe there were a large bunch of data to be seen just plugging it in. Wrong? Do I need to use configuration and a laptop to see all the data. I was specifically looking to see boost/air fuel. Where am I going wrong here? I definitely appreciate your getting back to me and hope you can get me under control here and straighten me out. TIAThere is nothing more required than simply plugging it into the OBD-II port. You can use the configuration tool to change the layout to what you would like, or you could add an aftermarket sensor to the display by running a wire to the AUX inputs on the unit. To get started, it is as simple as plug it in and start the car. If you have a more specific question, I would be happy to help you out.
