Parking Brake Front Cable
MR. T.
Manitoba, Canada
1977 Light Blue
I have run into a problem and am looking from some advise. I am replacing the front cable as part of a re-build. Is there anyway to get the cable through the pulley without removing it? The problem is I can't get the pulley bolt out, as it appears it is seized in the spacer. I have soaked it with penetrating oil and had a go at it with a hammer and punch. Any ideas?
The ball on the end of the cable is too big to go thru the bracket the pulley mounts on. Depending on what you're after for a final result, you can saw the bolt off inside the bracket and then replace it all, or open up the bracket with a pry bar so the ball will go thru it then straighten it out again.
Me, I'd replace it all. No sense screwing up a new cable
