Help! Passanger Power Window
bowtie123
New member
The Villages, FL
1961 White/Silver/Red
Hi,
2003 Convertible
The passenger side power window won't go down.
The drivers side, passenger side and hatch release buttons
will not lower the window, although there is a click when any
are pushed in either direction.
I had this problem on my '78 and it turned out to be the
drivers side switch.
What is the best way to determine if its the switch, motor
or just stuck.
Thanks for any information.
Hi,
2003 Convertible
or just stuck.
See thread entitled "comm issues" dated 10-12-2011. This thread may assist you with your issue.
Good Information
Thanks for the reference link.................Great information
I had just washed the car and went to put the top down when the passenger window stopped working. The next day I slammed the door and push the button a few times and it started working again. I let the car sit in the garage over the weekend and went to put the top up this morning and
neither the top hatch or the rear hatch would open. I drove to my destination, about 3 miles, with the top down and when I got there all was working well again. I brought the car about a year ago with only 10,000 miles on it so it has sat for a long time. I had a '99 convertible which had the same
problem, but was under warranty, so the dealer took care of it. I will try the door wiring trick if it happens again.
Thanks again
I had the same problem and the window finally just wouldnt go up or down, took it to get fixed and the reguator had went bad, $700 later my window was working!
