eRiCdWoNg
Need some help with this one, when I press "memory" on my door the right mirror will aim towards the left. If I press it again it goes to the left some more. This happens every time I put the key in the car with the door closed as well, so I have to redjust the damn mirror every few times I drive the car. Very annoying. What the heck is going on here.
The mirror fully articulates in all directions just like it should. The only variable I see, is I replaced the mirror motor cause I ruined it by backing into the garage once. The replacement motor came with crimp splices. I used those the first time but it still did it. I cut those off and soldered and heat shrunk the connection. It still does it even after that.
I pulled the battery for a few days (waiting for parts on another project), no dice. It still does it. I suppose I will clean the ground next once I find out there it is. Perhaps replacing the BCM is in order on that side...
Help!
Help!
