Tstorm
Hey all,
I have not posted alot on the forum but I read often. You guys are great!
I need to vent though. I purchased a set of Patriot heads about 2-1/2 yrs ago, then the problems started. First, I could not fit the rocker arms under the stock valve covers as they interfered on the intake side. Gave them a call then, they said "never heard of that". These are SBC Freedom heads and they obviously changed the geometry. No problem, i got out the old grinder and moved on. Now I do not drive the car as much as I would like, so there is about 125 miles on these heads. Since install I have had the following issues;
- snapped rocker stud, 3 bent push rods, 1 pushrod bent so far it snapped about half way around, 2 pushrods wore through guide plates allowing the rockers to rotate off the valves.
I have assembled a few engines in my time, so I am pretty sure I set the valves correctly. Used the pushrod length tool with some marker on the valve to get the correct pushrod length. Adjusted while on the stand to get close. Fired it up to get the lifters pumped up, then adjusted agian while running.
I just explained this to the "salesman" Jason Collins at Promaxx looking for some technical info, any issues they know about or the like. The response I recieved was, well less than customer friendly. Basically told me he is one of the new owners and since they purchased the companies asssets from the bank they are not liable. But he did ask what I would do to fix them and told me "we will see" WOW.
Sorry for the long read. I think my problem is the valve springs. The cams lift does not exceed the advertised max lift on the heads, but I cannot think of anything else that would cause these issues. I also know they had problems with their springs. Any ideas? And a final word of caution on dealing with these folks, just don't do it!! Thanks....
