tat2ed
I need to hook up the pcv valve on my 383. I'm not sure where I'm supposed to hook it up to since the previous owner removed it and just left the grommet in place. I have a breather and oil filler on the driver's side and the opening for the pcv valve on the passenger side. Does the pcv valve connect to the air cleaner ( which is an edlebrock aftermarket ) or does it connect to the carb vaccuum port? The breather also doesn't connect to anything. Looks like it just is an open breather. Is that ok? don't see any connection on it. Thanks
