Pcv Valve
RLE80L48
Central Pa.
1980 Black L82
If you were to put breathers on the valve covers can you plug the hose at the carb and eliminate the pcv valve? OR would doing this cause a blowby or leak problem?Just got the new covers and am about to mill holes in them. Thank ya.
Personally, I'd leave the PCV valve. It's a good system. If you look at full race engines, they may even have a vacuum pump to aid in extraction. Low pressure inside the crankcase is good for performance and engine life.
Joe
The PVC system serves a purpose, ever work on a car pre PVC, they build a serious case of sludge. PVC is good.
Mike
Definately leave the PCV valve. Mikes right, older pre-pvc cars almost always had a problem with sludge build up.
