66 big block
with pertronix II anyone try opening spark gap from .035 to??
thanks John I was told you could open gap to about .040 so stick to.035?JohnZ said:The Pertronix module is simply an electronic switch, replacing a mechanical switch - it doesn't create a "hotter" spark.
charlie yes i did buy coil so ill try .040 gap thanks johncfalson said:A pertronix module will not increase spark, it increases duration, a little at startup. Now if you add the coil, you can open the the plug gap to .040
Charlief
66 Coupe
BarryK said:John
why didn't the factory hook up the vacuum that way from the factory? was it some kind of emissions game they were doing?
