Glensgages
mr mctavish:
I'm just curious, but why make the change to 'only' 3.31s if you are also going to an OD transmission?
I'm not 'up' too-much on the aftermarket 5/6-speed transmissions offered, but I'm under the impression that the 1st gear is usually a bit deeper than the GM-transmissions, and that 5th/6th gear is well under 1:1, often .7/.6:1.
If the is true, 3.31s coupled to a .7:1 OD, would be 2.31 final-drive ratio, a full 17% taller than what you have now.
I'd think that 3.55s (2.48 final-drive), or even 3.73s (2.62 final-drive) would offer more 'spirited' performance, and yet deliver a 'taller' final-drive.
Would the lower 1st gear of the TKO, coupled with the 3.55/3.73 be 'too-much'?
Do you really NEED 17% more gear-ratio in every-day driving?
(Please bear with me: I'm just a bracket-racing, THM400-jamming fool...)
