Car was converted by a Place called Corvette engineering in Perth, they have a engineer i.d plate on the firewall to say when it was converted to australia design rule, etc
Yeah because the the engine is offset does make things a little tight on the right hand side, no need for smog eq here on 81, or cat, gone with a vac adv dist and normal q jet, next projects for this are 700r4 conversion, run the exhaust through the middle and modify the right hand floor pan so i can have factory electric seatS too! If you can see i made the power seat switch panel in reverse my self.
