Pictures needed
  • Thread starter Thread starter saxybill1
S
saxybill1
Some of you may know that I have been working to replace the gasket on the intake manifold. Well, I'm just about done; however, I very much need a couple of pictures to finish.
1. Next to the distributor is a pipe on a swivel fitting, it's about a 1/4 inch pipe. I have no idea what this hooks up to, so I'll need a pic.
2. Under the plenum and very close to the thermostat, just below on the manifold are 2 bolt holes, I believe I know what goes to one, but not the other.
3. On the plenum, right side back, are 2 nipples, what goes in each?
So that I'm not further confused, I would appreciate pics if possible and close enough for my specific application.
The 91 coupe has not been started yet, just hoping you folks can help before I start it. Also, I did mark onto the distributor the relative points of install; however, when installing the distributor, those marks disappeared. What are my options in making sure of proper alignment? I do now have a timing light should this help in eliminating any potential problem(s).
As always, thanks very much.
Bill
