D
Doug78
I pulled my baby into the garage to check the torque convertor for a loose bolt. After sitting for about 3 hours to cool-down (following a 120 mile drive) I starting jacking her up. I noticed a puddle of gear oil under the rear end. It appears to be coming from the pinion seal. What is involved in changing this. Do I just drop the drive shaft and pull the pinion yoke or do I need to completely disassemble the rear end. I've changed rear gears on a GM solid axle but I've never worked on an IRS. If it's more than a one day job she will get parked for the summer :cry
:Twist
