krscholz
Have you considered which kit to buy when rebuilding your power steering valve? The prices are all over the place and each kit is different. Don't make the mistake I did. Recently, I purchased a valve rebuild kit from Corvette Central. I thought that buying the more expensive kit would include all that I needed. I was wrong :nono. As I later learned, the kit was missing some key parts (I.e., rubber seals and rubber washers). If you're rebuilding a hydraulic value of this nature, what's the sense if you don't have new seals? This was, of course my mistake and I shouldn’t have trusted Corvette Central. Make sure you don’t make the same mistake and check to make sure that your kit has all the components you will need as rebuilding the valve is not easy and you don’t want to waste your time doing it again for a couple minor items.
