HI There,
There are alot of variables to the piston slap issue.
First, it will NOT in any way create an unreliable engine. IT is strictly an annoyance.
Second, in late production 2001, all Gen 3 engines were equipped with polymer coated pistons, that reduce the piston to bore clearancing in the engine. This virtually eliminated the piston knock concern.
Third, this is mostly due to the fuel formulations that create carbon deposits on the piston crown and the ridge going to the first compression ring land. This ends up creating a rocking motion of the piston, until the piston skirt gets warm and is tighter in the engine.
You have a 2004, so I do not believe that you will have a problem. If you end up having a concern, you might try a bottle of 12345104 or Techron to burn up the carbon that would be creating the condition.
Allthebest, c4c5
