mutley
does anyone know if there is a plastic fuel tank available for the c4 ?
Thanks Hib. so then the rust that is getting in my filter must be coming from the fuel pipes ? would that be correct ? and if so would i need to change them or is there a way around it. i havent actualy looked in the tank the rust in the tank is just an assumption i made. im way too busy at work fixing other cars to be fixing mine unfortunately just trying to gather info so as im led in the right direction of repair.
thanks boys foe your advice... I took the pump out today ... i think i found the problem. The earth lead that is connected to the pump is tacked on to the body of the pump but the body of the pump right by the earth lead is so badly rusted that the body of the pump has expanded and flaking away. It is only a small spot but it is right where the earth sits so when the exhaust gets hot , the rusted connection is causing the earth supply to tricle to the pump because rust is not a good conductor so its a bad earth so until my new pump arrives i will re-supply a better earth to the pump via a good point of the chassis from underneath and test it to see if it cures the problem. I had a word with an auto electrician and he said that would definately cause a problem wether or not it is the cause remains to be seen but its definately is a problem so we see how we go .
will let you know how we get on.... does what i found make sense to you guys too ? by the way there is no rust in the tank.
There is acually a white plastic well in the tank that the pump sits in so its always imersed in fuel.you're going to have to actually look in the tank before making any assumptions....
the steel lines in the pump/sender assy can rust if neglected for long periods. They can be cleaned as well.
Takes 10 min to get the assy out and your face IN the tank.
Siphon the fuel out and use the suction to "vacuum" the tank bottom and any loose stuff floating around. Then reach in with a clean rag and wipe out the remaining specs of dirt. Not a big deal. Just work in a ventilated area, with fans. Not IN the garage. IF there is a lot of crud in the tank...plan on replacing the inline filter/ pump and strainer at the same time. If trash made it to the filter, it had to go thru the pump to get there. Impending failure, so be pro-active and fix it before it leaves you stranded. If you do any "spirited" driving now is the time to construct a "pump well" to keep the pump submerged in fuel at all times under all conditions. Works very well, and can be made with common materials found in the garage. If interested send me a PM and I will send you the details of the project. Solves many problems with C4 fuel starvation and pump wear from sucking air.
Thanks boomdriver i would like the plans if possible.yeah....
about that little tray.
Chances are they it'll get broken off when you re-insert the pump with the screen down there. The pump sits right in or on that thing and as you position the top plate the pump beats against that tray and pops it off the tank floor. Its just glued on...and completely inadequate anyway. You'll discover this the first time that you exit a corner and apply gas when you are down to 1/4 tank of fuel.
This is where some of your problems may have originated...
Whenever this happens the pump sucks air for a few seconds. As the pump runs dry the rubber impeller starts to chew itself up fr om no lubrication (gasoline) and bits of the impeller plastic get pushed into the system to be captured by the fuel filter and mistaken for rust. Its often hard plastic or rubber bits. Pump wears out, cars starts performing poorly and the cause is not discovered until the pump fails completely and has to be replaced.
Thats why I designed a "well" thats 6-7" deep, completely DIY project thats a 30 min job, and allows you to keep the pump fully submerged in fuel no matter what the tank level is.
I'll find the basic instruction and post them. If you have some tie-straps or stainless steel safety wire, some other typical automotive maint items in the garage or house, you can build this is minutes, drop the whole mess in and forget it. It solves a lot of problems.
The pump is cooled and lubed by fuel, so whenever the tank gets low the pump gets hot and tries to run dry. That can cause them to stop or seize. Once they have worn to a point they may still pump fuel but its not the volume thats required and the pressures are going to be reduced. Poor engine performance. I think that most intank fuel pumps wear out from running dry or running in low tanks where they do not get enough cooling and lube.
