Mad-Mic
Gone but not forgotten
i played with timing tues night with a friend thats from www.thirdgen.org . he works at a shop that specializes in F-Bods www.fbodycentral.com the timing is bumped up to 10-12 degrees. got a base time with the timing light but the damn dampner was greasy and only seen 1 of the marks. didn't help that it was dark with the outside flood light on and a flash light :gap (backyard mechanics 101 at it's best :gap) so Tony and i took that for the base time and bumped it up twice with 2 test runs. no pinging at all and at a 10 mph roll she wants to break the rear tires loose on a WOT romp! i can feel her break loose alittle but not alot. 20 more hp or so i think she will so after i get some simple green and clean the dampner up some we are gonna retime it.
mods done upto date:
Mostly stock all "free" and "cheap" mods K&N open air box, MAF descreened, TB Bypassed, 160* T-Stat, Accel Super Coil, timing set 10*-12* degrees and No Mufflers just turn downs on the rear Y pipe. she already had an air-foil on the TB. Freshly Tuned up 3 weeks ago.
Front Y pipe going on saturday with a fresh oil change might be buying Tony's 3000 stall convert cheap. his wholesale cost was $450. he wants a tighter stall because his 89 Trans Am is his everyday driver and i think that will seriously help my 2.59 rear gear with a set of DR's 1.7 60' 's here i come!
i'm going to Test and Tune Friday night. if i can get her staged at 160ish water temp and hit a low 2.0 60" and run 98-99+ mph i think she'll brake into the 13's. i'm starting to have serious traction problems now i know how to launch the car. spring time i'm gonna need a set of DR's. i see this coming after the intake/cam/reworked heads swap especially!
tonight, with the dryer air, i took her to school tonight so i could play alittle when i got out. definetly no more bog at all! i am so happy well lets get onto it.....
i can definetly hear the rear wheels spin over on the 5-10 mph punch. at idle in park or neutral i sat at school and just listened to her. jabbing the throttle from dead idle 600 rpm to 2000-2500 rpm. it is real crisp with no bog. i thought the bog was from a rich factor that these cars have. launches are more consistent and real hard! i stopped on a back road and stalled out maybe 1100 rpm and let her rip. WOWSA! those 285/40/17's with the 2.59 rear gear lit the *^&$ up! seen average of 4700 rpm with a spike of 1 yellow bar around 5100 rpm then backed back down to around 4700 rpm and finally hooked. when she hooked i immediatly slapped into 2nd gear and she bit hard with a nice loud chirp at 4900 rpm. she's never spun up from a launch to 5100 rpm! now if i dead idle romp her she'll spin up to around 3500-3700 rpm then fall back alittle to around 2700 rpm when hooking. before the timing this is how the car reacted unless i max stalled it and got lucky with the launch. it always seemed like she'd fall on her face unless i got the perfect launch but now i am truely impressed with the L98 pretty much stock.
sheez she is starting to come alive.....Alive i tells'ya!
*Edit: this post is actually a 2 parter from my front Y pipe question post with what i noticed tonight
